Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Schematic vs parts list - what trumps what?
  1. #11
    Forum Veteran marcok's Avatar
    Join Date
    Jun 2014
    Milan Italy
    Posts
    464
    Quote Originally Posted by laatsch55 View Post
    Gary, if it's one thing I've leaned, it's that documentation canb NOT be taken as gospel, as soooooooo many revisions of this or that were never documented. The boys on AK taught me years ago, it's what's on the board that is right, if the schematic and parts list agree , well, that's icing on the cake....
    I do agree .
    PL 4000 ( 3 versions ) and 2 service manual versions .
    PL 400 and 700B ( many versions )
    Carver C4000 ( 3 versions )
    Carver M 400 ( 3versions )
    These are some examples !!!
    Solution : study and ask !
    Ciao
    Marco
  2. #12
    Forum Veteran 62vauxhall's Avatar
    Join Date
    May 2014
    Greater Vancouver Area. BC
    Posts
    1,298
    Quote Originally Posted by Bradrock View Post
    Nah, I've just had Commander Cody in my head since 1972
    When I see his avatar I am 'triggered' A macro agression into my micro mind.
    "....My dog died on me yesterday,
    and left me all alone.
    The finance company came by today, and repossessed my home"
    "But that's just a drop in the bucket,
    compared to losing you.
    And I'm down to seeds and stems again too"
  3. #13
    Join Date
    May 2014
    Posts
    1,298
    For some reason I thought a schematic would be the more concise of the two. But I too have seen discrepancies comparing diagram with what was physically on a board. In that case though I attributed it to being a NAD thing.
    Regarding the Teac I'm pondering now, the schematic has two R6's. One of them is mislabeled as it should say R8.
    The wattage of those two components don't match either but at least the resisistances do. The schematic indicates they are one watt higher than the parts list says. If I pursue this, I will go with the higher wattage.
    I cannot refer to what resistors were on the board when I got the deck because they got carbonized and replaced.
    Last night I noticed something that got me wondering - why? When I quit the work, I had what looks to be an 88 ohm resistor half soldered in where a 3.3 is what is called for. I cannot for the life of me remember why that would be. Unless perhaps that was one of the suggestions made by the TH poster. It also may be I questioned that move and why I heard nothing further.
    Between then and now, I learned a bit more about schematics than I used to know which was not much. Am I wrong in thinking voltages should be documented on various parts of the circuit? Because there are next to none on this one. I think I identified what wire supplies power from the transformer and I'll have some time this weekend so will check for what might be present. If I can't make sense of that, I may just abandon this thing for good - sell off a few parts maybe.
  4. #14
    Forum Veteran WOPL Sniffer's Avatar
    Join Date
    Aug 2015
    Arizona
    Posts
    2,919
    Maybe on a "new" board things May be kosher, once a dirt bag has monkeyed with it, then nothing is correct. Sometimes the schematics have errors however, they are more correct than a circuit board that has been touched. We were taught in school to go by the skizmo while scrutinizing the board also. Use what you got. After 40 years, its hard to find a virgin.
    I had the nations problems figured out one night while on blah blah blah........ huh?
    Big amps
    Kenner Close N Play
  5. #15
    Forum Veteran Netfly's Avatar
    Join Date
    Jul 2017
    Posts
    306
    Quote Originally Posted by 62vauxhall View Post
    .. Am I wrong in thinking voltages should be documented on various parts of the circuit? Because there are next to none on this one...
    Unless otherwise advised, that is often at the discretion of the person making the schematic. Is he documenting it so he will remember what to look for later? Does he really want people to know how it works? Maybe, maybe not. Usually a separate production test document will contain where to test for what voltages during production test, but that isn't typically shown on the schematic.
  6. #16
    Forum Veteran rtp_burnsville's Avatar
    Join Date
    May 2011
    Savage, MN
    Posts
    844
    Lee summed it up pretty well..... After playing engineer for several decades I'll just add that sometimes all the docs are all wrong and that design errors have been known to have been manufactured (sometimes for years!). About all one can do is reverse engineer what is found and devise a solution for what the circuit should do. Also beware that replacement parts may not perform as the originals. Sometimes a circuit makes use of a part 'feature' that was never spec'ed or tested. When a so-called 'exact replacement' is inserted things go very bad, very fast.
    Robert
  7. #17
    Join Date
    May 2014
    Posts
    1,298
    Glen talked sense yesterday, suggesting a replacement board I saw on e-bay was the best solution so I bought it. Untested, but intact so a $30US gamble. Guess I'll see what happens with this thing in a week or two.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
