Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Phase Linear 400 Fan Assembly Project
  1. #1
    Journeyman Member
    Join Date
    Apr 2017
    Posts
    31
    Recently i went and did full pl400 rebuild and i must say i'm am very happy with the results.
    I have 4 ohm AR98LSi speakers which make my pl400 very hot, It does not help that i have it seating in the wood case inside a stereo cabinet. there is no air movement and it gets hooot!!. i was looking for a fan to install and i realize that there is nothing there to get. I see many homemade solutions and i thought that i have to come up with my own solution.
    Well im not a expert when it comes to designing but i have ideas, and i would like to share one of them with you. Please be easy on me, lol.
    I decided to make a design that would meet the following requirements.
    - easy install simple design
    - two fans - one for each channel
    - fan control board to control fan speed based on the temperature
    - something that i can afford and make myself. (i spend all my $$ on the upgrade lol)
    I order all the necessary parts , some of them already came, and some are still being build by small children in china / not funny but true.
    I decided to build a fan housing using a 3d printer.
    My printer can not print one big piece so i made three pieces design, which once assembled will make one piece.
    Piece I: Right channel housing
    Piece II: Control board bridge
    Piece III: Left Channel housing
    I made the design for right channel and the bridge pieces and i get rest of my parts i will measure them again and if everything checks OK, the printing begins
    here is the Right Channel housing design
    Click image for larger version.
Name:	Right Channel 1 .jpg
ID:	29667Click image for larger version.
Name:	Right Channel 2 .jpg
ID:	29668Click image for larger version.
Name:	Right Channel 3 .jpg
    the design is for a 4 fin sink, where the housing is force-fit onto two outside fins for each channel.
    it holds one 80mm fan which will blow air in and then hot air will exit out around the fan(remember i have a wood case). or the fan can be install to pull air out. i don't know which will work better.
    Right and left Channel housing will be connected together via the control bridge piece which will be seated in the space between right and left heat sinks
    here is the bridge piece ,
    Note: i will include into the design power switch, 12v female input connector for a power supply, control board, thermal probe, and fan failure buzzer once i get all the parts in.
ID:	29670Click image for larger version.
    Please let me know what you think and if you have any suggestions i take them now before the printing.
    Thank you.
    Pioneer SX-1250 | Accuphase P-300 | Accuphase C-200 | PL-400
    Cerwin Vegas VS-120 | AR 98LSI
    Marantz 6300 | Pioneer PL-530
    Sony TC-755 | Sony TC-756 | Sony TC-758 | Sony TC-788-4 | Revox B77 | Revox PR99 MKII
    Pioneer CT-F1000
  2. #2
    laatsch55's Avatar
    Join Date
    Jan 2011
    Posts
    53,838
    i LIKE IT BUD, VERY ELEGANT solution...
    taking something that's already good, and making it better...........and for the knowing smiles that cross their faces.......Nando-2011...
    "Silence cannot be Misquoted"--Lazarus Short-2012 "
    " I Just Collect Smiles Craig......Cheap Smiles!-----Fishoz-2017
    "anything can be done, it's finding the easiest way that's hard"-----Bobbysdad--2014
    " Synth percussion is deadly to children, house pets and shitty power supplies"---Stephen Evans 2014
    " You have not reached the point of diminishing returns, you've just ran out of money
    " The Pioneer U-24, unfortunately, is just too expensive and rare to find. That's why I have one."--Nando-2014
  3. #3
    Forum Veteran bill7621's Avatar
    Join Date
    Jan 2016
    Berlin Center, Ohio
    Posts
    336
    I like it too. What are you going to use for the fan controller or are you designing your own?
    Some people are like slinkies; Not really good for anything, but sure bring a smile to your face when you push them down a flight of steps
  4. #4
    Journeyman Member
    Join Date
    Apr 2017
    Posts
    31
    There are few available PC fan control boards which should work just fine. i have two coming to see which will work best. For the price it is not feasible to design and make one.
    Pioneer CT-F1000
  5. #5
    Journeyman Member kingman's Avatar
    Join Date
    Mar 2017
    Posts
    43
    BRAVO!!!
  6. #6
    Forum Veteran
    Join Date
    Jun 2017
    Alton Mo.
    Posts
    476
    ---I run with Scissors
    There will be bonus points if you incorporate this very 'COOL' item, instead of just a boring fan:
    http://www.ebay.com/itm/12V-6A-DIY-E...3D122245768468
    There is quite a variety of ideas when I searched 'Semiconductor Refrigeration'. In the past , I've alway's just searched for 'cooling fans'.
    How about the electric refridgeration pads for laptops?
    If gaming desktops can have refridgeration, then why not hi fi equiptment?
    https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313.TR1.TRC0.A0.H0.TRS0&_nkw=Semiconductor+Refrigerator&_sacat=0
  7. #7
    Journeyman Member
    Join Date
    Apr 2017
    Posts
    31
    Lol. This is nice but overkill. 5A to run it lol. And 3 fans. I wonder how loud it gets. I might just get one to play with it.
    It is design for cpu. It won't work well with pl400 cooling heatsinks, i don't think.
    Condensation is always an issue with this kind of cooling. I used water cooling for my PC rather than refrigerator coolers due to the frost/condensation build up in high humidity environment.
    Fans are boring.... But they get the job done hehe.. the ones I intend to used run off 0.16A each. Variable speed. Very quiet, I hope.
    I will attempt to print first piece on Monday. One part will take 11h to print, if everything goes as planned.
    Pioneer CT-F1000
  8. #8
    laatsch55's Avatar
    Join Date
    Jan 2011
    Posts
    53,838
    3D printing ain't fast, that's for damn sure....
  9. #9
    Forum Veteran Billboard's Avatar
    Join Date
    Nov 2015
    North Shore Massachusetts
    Posts
    246
    I need to add some fans to me PL 700B, they drive a pair of 4 ohm speakers (Ohm Is), and the amp does get hot, and will shutdown if I run it too long at a high volumes. The pros had trouble cooling these amps when they were used for sound reinforcement, I doubt a couple of muffin fans will be enough.
    But couldn't hurt I guess.
  10. #10
    Forum Veteran orange's Avatar
    Join Date
    Jul 2010
    Posts
    15,045
    If you're needing fans to prevent thermal shutdown, forget switching, they come on the moment the amp powers up. Later is too late.
    If I don't really exist then at over 15,000 posts my nothingness has longevity, if not serious mojo.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
