Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
Thread: PL D500
  1. #21
    Forum Veteran WOPL Sniffer's Avatar
    Join Date
    Aug 2015
    Arizona
    Posts
    3,211
    The pots would get "Flat Spots" so to speak and no amount of de-Oxit and twisting would fix them.
    I had the nations problems figured out one night while on blah blah blah........ huh?
    Big amps
    Kenner Close N Play
  2. #22
    Join Date
    Aug 2015
    Arizona
    Posts
    3,211
    Quote Originally Posted by Quickcarl View Post
    It may be just an alignment issue and not the LED or the drivers at all. The more I look at it, the more it looks as if the number plate is shifted to the left.
    One of the reasons I was looking for an updated schematic is this amp will turn-on normally, but once it has warmed up for 10 min or more and I turn it off, then attempt to turn it back on all it does is hum. It has to cool for about a half hour then to will turn on normally. At least until it heats back up.
    The number plates can't shift. They sit on posts with nylon inserts. Unless there are parts missing. Let me know, I have some meter mount parts.
    Big amps
    Kenner Close N Play
  3. #23
    Join Date
    Mar 2018
    Florida
    Posts
    13
    Will do,,I will be pulling it apart next week once I get back in town and attempt to see whats up.
    Carl
  4. #24
    Forum Veteran
    Join Date
    Dec 2012
    Orlando
    Posts
    129
    Wanted to revive an old thread, hope you guys OK with it.
    Thanks THD+N for the updated Schematics for the D500. Appreciate the hard work.
    But I have to ask, since I wanted to work on my LED meters over the next few weeks.
    Did you ever finish your updated rendition of the LED meter control section??
    Carl
    Carl,
    I have not redrawn any other sections of the D500 yet.
    Nick
  5. #25
    Join Date
    Jul 2017
    Posts
    12
    Phase linear d500
    I have the amp with a service technician that states the amp is now working n both channels however one of the gain LED gain sections is not working. It will not move at all when gain knob is turned. He states the schematic only shows 2 IC's but there are 4 on the LED board. Any ideas how I might approach diagnosing it? thanks
  6. #26
    Join Date
    Jul 2017
    Posts
    12
    Phase linear d500
    My technician has repaired both channels now however one LED gain section is not working. Any ideas?
  7. #27
    Quote Originally Posted by vmaxman View Post
    Do you have a copy of the D-500 service manual? See section 6-10
    Ed
  8. #28
    Join Date
    Jul 2017
    Posts
    12
    Phase linear d500
    My service tech was able to get both channels operating however the LED gain lights do not move when knob is rotated. Ideas?
  9. #29
    Forum Veteran grapplesaw's Avatar
    Join Date
    Aug 2014
    Vancouver
    Posts
    1,216
    First thing to check are the signal feed to the meter. These come from the rear big relay. That wire may be broke three or at the mutipin on the meter board in the middle. Check the appproperate meter board terminal pin with a volt meter while running that channel with a signal tone. If you have voltage them we need to go further into this.
    try the Lightening Bolt WOPL 1000 for a hair lifting experience today
    Warning !!! Use only when you want to blown the town down
    proud father of the only WOPL Fully Comp dual 500
  10. #30
    Join Date
    Aug 2014
    Vancouver
    Posts
    1,216
    Schematic can be found in post 1 of this thread.
    http://forums.phxaudiotape.com/showt...500-schematics
Similar Threads
  1. PL D500...
    By johan1212 in forum Forum Buy/Sell/Trade
    Last Post: 03-09-2016, 10:59 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
