Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Thorens TD125 MK ll running again
  1. #11
    Forum Veteran grapplesaw's Avatar
    Join Date
    Aug 2014
    Vancouver
    Posts
    1,117
    Quote Originally Posted by 8991XJ View Post
    Nice the later TD-125 and the earlier SME. Nice combo.
    I had a 125 II with a 3009 S2 Imp and it was a great turntable. Memories forever of the first hearing of Pink Floyd's WYWH. Missed that table. Finally a year or so ago found a 125 (no II), a friend gave me a deal on a 3009, same S2 Imp, gave me a dust cover and hinges and I rebuilt a table that I had 32 years ago. Longer down time without.
    My friend had those parts available because he had a new base made for the table and the dust cover didn't fit it and he put an audiomods arm on the table, removing the SME. I'm happy with the combo and even though I have swapped in my Magnepan arm, I'm keeping the SME. The 125/SME is The Classic Turntable and just looks right.
    Glad you got yours back up and running properly. Did it get a recap? I did this with my friend's 125 II and it improved it overall response to the power switch.
    great story
    the motor is slow starting so a new cap may be the ticket. I will look into it.
    Thanks for your approval.
    Glen
    try the Lightening Bolt WOPL 1000 for a hair lifting experience today
    Warning !!! Use only when you want to blown the town down
    proud father of the only WOPL Fully Comp dual 500
  2. #12
    Forum Veteran stuwee's Avatar
    Join Date
    Jun 2010
    Deep in the Sonoran Desert SW
    Posts
    8,026
    I'm very happy for you! I've had mine since '77, they need some sewing machine oil every few years. I highly recommend you not use it till you get some oil in that motor. Do a search on putting oil in the motor in the 125 MKII. It's pretty easy, lock the arm, flip the TT over, heavy bitch ain't it?
    Remove the 4 footer screws, be OCD and put them back in the same place, don't over tighten, you just need to secure the particle board base.
    There is a tiny hole to put a few drops of oil in there, that should help your slow start issue...are you sure the belt is the right one?
    It should last you till you get called home many years from now, you will not find anything better unless you want to spend $10,000+, enjoy!!
    Documented SAE Fanatic
    New owner of Martin Logan Summits, driven by the SAE A1001
    It's always the beautiful ones that smash the picture ~ Teena Marie
    Huh? What?? Hmmmmmmm
    I'll never get over you, you'll never get under me ~ A-Ha
    To the bat cave 'stat boy wonder!!!! ~ Finebar4
  3. #13
    Forum Veteran 8991XJ's Avatar
    Join Date
    Oct 2011
    Posts
    253
    Quote Originally Posted by stuwee View Post
    Remove the ... particle board base.
    Yes, it is one heavy table for what it looks like.
    The bottom cover, this needs to go. One improvement on the TD-160 Super over the TD-160 was replacement of the hardboard bottom with a chunk of thicker MDF. I believe the same can help the 125. I use mine without a bottom cover right now.
    This speed adjustable Thorens is one of the few Thorens tables that can compensate the speed when using a non-Thorens belt. All non-Thorens belts I have tried on my TD-160 Super provided inaccurate speed. There will be different start characteristics with a non-Thorens belt that would effect the 125, though.
    Recapping these today is something that makes the electronics respond better. The speed can be set to center the speed adjustment wheel, the neon lamp comes on immediately, the table starts right up and well it is just better, like it is supposed to be. On Mike's table, I upgraded the older board (still a Mk II version) to the one with fewer parts. This is a job described on AK at http://www.audiokarma.org/forums/ind...opping.348375/ Speed improvements included less clutch chatter if any, quick to speed and accurate speed from the start. All around just better.
    As for the $10K spendable to replace the td with anything better. I know a Thorens guy who bought a Clear Audio (used, many upgrades got a deal) that had a combined retail of about 6k, I'll say it again, he got a deal. He says it is a 40% improvement in sound quality from his records. This was enough for him to swap the starter Graham Slee arm with a new arm. This teaches me that the 125/SME is a grand old table that can be beat without too much trouble but it will cost at least a few grand. And these 125s have new thrust plates, polished spindles, new oil for the motor and the spindle, one with a nice new thicker solid wood base that also helps a bit.
    Those of use that like the vintage gear do get a little off base when talking about new gear to be the equal to what we know and love. No problem, I'm there, too. The Magnepan Unitrac is the equal of arms up to about 1500. Haven't proven it, but with the right cartridge, that might go higher.
    5F70, CS-6, MS-10, K-12, RX-103, T-110 x 2, K-112, D-117, K-117, G-120a, L-580, C-1000, R-1040, R-1050, R-1120 x 3, MB-3045 x 2
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
