Page 27 of 27 FirstFirst ... 17252627
Results 261 to 268 of 268
Thread: Resurrected Customized WOPL 400
  1. #261
    laatsch55's Avatar
    Join Date
    Jan 2011
    Posts
    53,858
    Not yet, still reading..
    taking something that's already good, and making it better...........and for the knowing smiles that cross their faces.......Nando-2011...
    "Silence cannot be Misquoted"--Lazarus Short-2012 "
    " I Just Collect Smiles Craig......Cheap Smiles!-----Fishoz-2017
    "anything can be done, it's finding the easiest way that's hard"-----Bobbysdad--2014
    " Synth percussion is deadly to children, house pets and shitty power supplies"---Stephen Evans 2014
    " You have not reached the point of diminishing returns, you've just ran out of money
    " The Pioneer U-24, unfortunately, is just too expensive and rare to find. That's why I have one."--Nando-2014
  2. #262
    laatsch55's Avatar
    Join Date
    Jan 2011
    Posts
    53,858
    Post 152 on pg 16 may have been some of your trouble. When you were having problems getting the power supply wired you could have caused this damage.
  3. #263
    Forum Veteran scottonnob's Avatar
    Join Date
    Apr 2015
    Posts
    199
    Quote Originally Posted by laatsch55 View Post
    Well, I'll check everything again. I don't remember the specifics of the problem in the post you referred to. So I'll go back and start over from that point for diagnosis. Thanks for taking the time to go through all that stuff.
  4. #264
    laatsch55's Avatar
    Join Date
    Jan 2011
    Posts
    53,858
    You powered up with the power supply wired wrong once in there. You got it squared away but never got this far since then. Replace the pico fuses and the 1 ohms and I think you'll be OK. Order some TL 431 voltage regulators too, just in case the -15 volt regulator is fucked...
  5. #265
    Join Date
    Apr 2015
    Posts
    199
    Okay, thanks. I'll get my Mouser mind going and order up. But you think the problem occurred way back when, and that it occurred because of a mix-up, mistake, fuck-up? So just get everything right this time and try again?
  6. #266
    laatsch55's Avatar
    Join Date
    Jan 2011
    Posts
    53,858
    Yep....
  7. #267
    Forum Veteran NavLinear's Avatar
    Join Date
    Apr 2012
    Posts
    5,590
    Survived the Thomas fire
    Quote Originally Posted by scottonnob View Post
    I think Dennis' life is a little nuts now. So I don't mind waiting a bit longer. He's come through a bunch of other times. It'll work out.
    Almost through this - another move at work that has/is very stressful plus the Thomas Fire shit. Previous dumbass management and a team move has keep us afloat. I could write a novel about this. Fcuk!
    If you get offended by the jokes and comments on here, go ahead and blame your parents... for raising a pussy.
  8. #268
    Forum Veteran WOPL Sniffer's Avatar
    Join Date
    Aug 2015
    Arizona
    Posts
    3,163
    Quote Originally Posted by Northwinds View Post
    This is exactly why I will never attempt one of these builds, I just don't have the patience. The amp would be flying across the yard by now
    Kaboom
    I had the nations problems figured out one night while on blah blah blah........ huh?
    Big amps
    Kenner Close N Play
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
