Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: La Scalla industrials
  1. #11
    Forum Veteran WOPL Sniffer's Avatar
    Join Date
    Aug 2015
    Arizona
    Posts
    2,919
    Quote Originally Posted by Geegz View Post
    I will look at the Cornscalla's also. My preference for music is less bass heavy anyway. HT I like more bass but these will be for a separate 2 channel dedicated music system.
    Cornscala's rock and Even if Bob and his crew build them they are only $1800.00 completed, ready to ship.
    Very nice price for a killer set of speaks.
    I had the nations problems figured out one night while on blah blah blah........ huh?
    Big amps
    Kenner Close N Play
  2. #12
    Journeyman Member
    Join Date
    Dec 2012
    Orlando
    Posts
    91
    Quote Originally Posted by OneTonScoutII View Post
    Everyone tells me that they are lacking in the low end of the bass.
    In stock configuration this may be a true statement. It depends on your listening habits. When I first acquired my pair of 1974 La Scala's, I was listening to a pair of Heresy's (1977). The La Scala's sounded "bigger and better" but they did lack a bit in the low-end. After porting the La Scala's (and using active EQ) per advice on the Klipsch forum, the bottom end of the La Scala's is much better and what I would call "normal" now.
    Lifting the entire speaker off of the floor about 4" also helped the bass and sound quality a lot. I put 4" rubber wheel casters on each speaker to lift them and make them easier to move.
    With a 400 or 700 connected to the ported La Scala's, you would think you were in a night club. Clean, clear and massive SPL.
    On the other hand, if you have a low power tube amp, the La Scala's will sound great too, just at a lower volume.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
