Page 1 of 6 123 ... LastLast
Results 1 to 10 of 55
Thread: Record Player buying advice needed.
  1. #1
    Forum Veteran
    Join Date
    Mar 2013
    Montana
    Posts
    106
    I am leaning towards a Technics SL 1400 because there is one for sale close to me for $150. What old Technics players are good and what ones suck? I was told by a vinyl junkie to find an old Technics and replace the cartridge if needed and it will work great. I was pretty shocked to have him tell me that after listening to his $25,000 speakers and $20,000 record player.
  2. #2
    Forum Veteran Lazarus Short's Avatar
    Join Date
    Mar 2012
    Independence, MO
    Posts
    2,522
    Those Technics turntables can be very good, if in good condition. The SL 1400 should be direct drive, so there is one thing to check on: cogging. A little is normal, but watch those dots at the edge of the platter. If they dance back and forth too much, it is evidence of excessive cogging, and so, look for another table. I got rid of my beloved SL 1500 for that reason.
    In case you don't know, cogging is the result of motor poles. As the platter turns, it is pushed at some points in its rotation, and coasts at other points. The speed difference between the push and the coast is the cogging. Too much will smear the musical notes.
    What an elder can see sitting down, a youth cannot see standing up. [old Yoruba proverb]
    Look! Isn't that Uncle Patrel in a...in a taxi?! [3Mustaphas3]
    But...you keep looking over your shoulder...to see if I am ​there... [Curved Air]
    Who gives water to a goose as the land brightens for the morning of its slaughter? [Egyptian, Tale of the Shipwrecked Sailor]
    ...more dust bunnies than a desert bordello... [Orange]
    Aziz...LIGHT! [Professor Pacoli, Fifth Element]
  3. #3
    Forum Veteran orange's Avatar
    Join Date
    Jul 2010
    Posts
    14,990
    I would not necessarily fault the DD for that. A cap is bound to be involved or even the bearings.
    I know NOTHING, I memorized it in school.
  4. #4
    Join Date
    Mar 2012
    Independence, MO
    Posts
    2,522
    ​As I wrote the above post I thought someone would disagree with me.
  5. #5
    Administrator Gepetto's Avatar
    Join Date
    May 2011
    Posts
    6,812
    Technics makes a solid TT. I have 2 SL1200 Mk2 and they work reliably and accurately.
  6. #6
    (and straight-up pimp stick!)
    Elite-ist's Avatar
    Join Date
    Jun 2010
    Posts
    7,403
    There are so many under-the-radar turntables, it would make your head spin which ones don't get the notoriety they deserve. I picked up an Hitachi PS-58 turntable, yesterday. Hooked it up today to the big Pioneer SX-1980 receiver. I haven't even bothered upgrading the cartridge, yet. Picked it up for $200. Going through some of the 80's 12" 45s I have.
    Join Date
    Mar 2012
    Independence, MO
    Posts
    2,522
    ​The Hitachi turntables are non-cogging. That is what "Uni-Torque" means.
  8. #8
    Banned
    Join Date
    Jun 2010
    Deep in the Sonoran Desert SW
    Posts
    8,047
    Hello BigSky, listen and look for what Laz says on these older Technics, they can be fine and last for years. If you are in no hurry, something may turn up later my friend. Maybe a Thorens??
    Nando, Niiiiice! Very cool! Love ya playin' the old 80's goodies
  9. #9
    Forum Veteran
    Join Date
    Mar 2013
    Montana
    Posts
    106
    Found a Technics sl 1300 that has motor issues for $50. Not sure how hard or expensive a motor is to put in. I was told to stay away from Thorens and Bang and olfussen. I found a bang and olfussen at pawn shop but I think they wanted a lot of money for it.
  10. #10
    Forum Veteran Northwinds's Avatar
    Join Date
    Mar 2013
    Posts
    7,181
    Quote Originally Posted by Gepetto View Post
    Yep, I use one also w/ a Ortofon MC20 Super II, no complaints whatsoever
    "I really can't begin to describe what happens at that frequency when you hit that SPL, but it's serious. We saw a mouse stagger out of a crack in the concrete floor and die"
    Quote Originally Posted by laatsch55 View Post
    Yweblwrs...
    Quote Originally Posted by skynyrd77
    The only toilet I have seen that didnt swirl was in a trailor
    Quote Originally Posted by TheWOPLwhiffer View Post
    now I need a Dim Bulb Tester to test my Dim Bulb Tester
    Quote Originally Posted by lattiboy, post: 11205733, member: 245918
    my eyes were forced shut by the air pressure change
    An audiophile is someone who's stereo is worth more than his car
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
